what are you guys running for replacement filters. im due for some new ones. what micron filter should i run?
You can back flush the Water separator with gas and call that one good. Its a wire screen filter.
As for the Fuel Filter on the FASS, you got several options.
Assuming you have a 150 Series FASS:
You can run our filters....which if you are not in a time crunch...that would be the cheapest way....they are Fleetguard filters anyway.
FF-1010 is the 10um filter
FF-1003 is the 3um fitler (I have ran this one for the last year with no issue..even on Bio)
Contact a FASS dealer for the filters. Use our website to locate one.
You can also cross to a FG number off our web site @
FASS Fuel Air Separation System - fassride.com - The Official FASS Website
If you have a 95 series FASS, you will need to contact a FASS dealer for filters at this time. Cross numbers are coming soon.
FF-2010 (We no longer carry)
FF-2003 is the 3um (Standard filter for the 95 series pump)
