2007 Dodge RAM 3500.
The 5.9l (ISB 325) is an integral bore block and dont have sleeve.
I am going to repair mine. Failures in the turbo caused severe damage to the engine.
I have read in some forums that can be repaired using sleeves, even recommending use the sleeve Cummins P / N 3904166 along with a standard kit.
What is your recommendation to make this repair.
Which “engine rebuild kit” do you recommend and where to buy it?
Do you recommend changing the oil pump?
any other recommendations is welcome.
