1 - 9 of 9 Posts
Hey guys, I removed my edge comp and sent it off(updates/hot unlock) and now I have little to ZERO boost according to my guage(I think I saw 4psi once on my way home). I can hear the turbo whistling away but its not building any boost. Kind of sad going up a steep incline at 30mph at WOT. Also I got 3 codes that I'll have to post later when I get home from work. I just bought a scan tool so Im thinking of trying to use it to reset the computer to see if that will work? has anyone else seen these symptoms when removing their chip?
Thanks
When you sent your comp in did you remember to plug your stock MAP sensor harness back into the map sensor.
Go for Broke
it's normal when you pull the box (no boost fooler) with everything else is still hooked up
it does suck driving around with no box :lol3:
Awesome thanks guys! I'll have to try that. Now what does this sensor look like? and where is it located? Sounds like that is definately the problem.
Located toward the rear of the motor to the right of the fuel filter canister. Your comp was pluged into it. Did you leave the comp harness on the motor or send it in with the box.
Thanks for the info....I left it on the truck.
You need to unplug the Comp harness from the Map Sensor, and plug the stock harness back in to the Map sensor.
Discussion Starter #9 (Edited)
Im an idiot...found the sensor unpluged the edge and put the stock on in. Now it works......thanks guys!
1 - 9 of 9 Posts
