1 - 9 of 9 Posts
2016 2500 longhorn Laramie 4x4 6.7
Some mornings my truck starts fine, others it starts then shuts off and says low fuel. but my tanks is half full. I get outside and truck is off and i get in and says remote start disabled low fuel. I hit the start button and starts fine and my gauge reads 1/2.
Have you changed the battery in the remote? Mine went about 5 yrs and started acting up.
I haven't changed it in a while. wonder why that would make a difference? it starts then shuts down and says low fuel. i just restart it with the button when i get in. ok i will try that thanks Sir
I doubt the fob battery will help but you never know. So fuel gauge is showing half full and no low fuel light is on?
no sir. i open the door and see that the remote start is active but says low fuel. i dont think the low level alarm is on. i will check next time. i just hit the button and it starts and guges then goes to reading
this morning it started then died again, opened the door and it just had the remote start low fuel in the disply. gauge was not reading or nor was there any alarms on anywhere.
2011 Ram 2500 4x4 6.7 68RFE 4 inch lift
If there are any codes, remote start won’t work.
Wonder if you have a loose or corroded connector on the fuel pump.
Sent from my SM-T500 using Tapatalk
Discussion Starter #9
well this morning i started it and died like it normally does, but the fuel gauge was reading low and fuel like was on once i started it. it took a minute for the gauge to come up to around 1/4 and fuel lite went off. maybe the gauge/sending unit is not reading fast enough for the remote start to get the reading before it goes above the low level reading.
1 - 9 of 9 Posts
