1 - 2 of 2 Posts
I am wanting to relocate the turbo from the side to above the valve cover and in the same process rotate the turbo where the exhaust inlet to the turbo is on the bottom. by doing this does anyone know if that would affect the turbo in any way?
you mean so the exhaust is entering from the bottom side, not exiting right? if so it'll be fine, you'll just need to clock the housing. just make sure the shaft sits level (for oiling purposes)
1 - 2 of 2 Posts
