1 - 3 of 3 Posts
i know some have said they are using a relay to make the hids stay on and not blink but how do you wire the relay into the system?
i only need to do the fog lights...
thanks
use the power wire off the fog light to switch the relay on/off, and pull a positive wire straight from battery with in-line fuse to power the relay. ground the relay and lights.
Haven't done the fogs, but on the headlights it was the relay with a positive and ground to the battery, a connector to one of the factory headlight connectors with a separate ground for that, and then the two lines connecting to the HID ballasts. I bought my relay for $15.
1 - 3 of 3 Posts
