I'm pretty sure that's low--I want to say like 5.6 or 5.8, but I'm not 100% on that --you can adjust the voltage by turning in the torx screw(it's hard to break loose)on the front of the APPS or TPS (depending on what you call it)-----you should call Chip and ask, but maybe someone knows exactly----also the REDLINE boxes for this year truck is known to need to have some upgrade work done to it, so that may be the issue---a resistor needs to be replaced or something like that----good luck.....chris
