Diesel enthusiast
Im in the process of rebuilding a 01' Ive already pulled the engine, head and #2 piston out and waiting on the guy to check the cylinder to see if it needs to be bored or sleeved. (Injector nozzle chipped off) So i guess, the question now is. How hard is it to rebuild one of theses bad boys? And also is there any special tools that you need?
Im looking at a complete rebuild kit. All gaskets, seals, bearing and pistons.
Also what are some mods that i should go back with?
One more question and im done. Lets say there is a chance i could have a 53 block. Is there any parts i could use and swap with a 12valve?
Thanks for all your info and comments!!
Buy the BEST CUMMIN 5.9 BOOK there is on the market if your going to do the rebuild or take it to a machine shop and let THEM do the work (warrenty wise)!!!
12 valve parts to do a ppump swap.
I have a block torn down in the garage -
Can get a good rebuild kit for about 975.00 with new pistons rings, bearings….everything.
I am gonna go with 40 over pistons and 12V rods when i do my build.
I have a 12V tore down as well so I'm not really out anything.
Diesel enthusiast
no p-pump here! And where can i get a book at?
ive got a extra 12v engine at the house also ithought about robbing some parts off of. If i need them.
Dirt, check for a Haynes or chilton book. eBay has a few.
