Obviously new shoes are a must = yes? Check your wheel cylinders since you're there. I've been there and done everything you are getting ready to do on yours to mine - rear brake wise it's been trouble free for about 80k
A tip - before you install the seal into the hub, a light coat of blue goo (form-a-gasket) in the hub/seal area will help prevent oil from working between the hub and the metal ring of the seal. Also, get the new "wedge" that holds the big nut in place after you torque it. Proper bearing pre-load is key - while turning the hub torque nut to 120# and back off 1/8th turn. I'm pretty sure its 120# - check the shop manual to be sure. Or, if someone else doesn't chime in to confirm/correct let me know (PM so I get an email) and I'll check for you.
