2001 ram 3500. should it be posi when i burn tire? cause i have never been able to get it to kick posi. and all my other friends dodges will spin both tires.
If it is a posi than it is too weak to grab or you have just an open diff.
dayna 80's come in both?
Rescue Tower
It could be open or LSD. They were equiped with both.
well both tires never spin, and the truck runs better than some of my friends, so it has the power. is it possiable to change the diff from open to limited slip without changing the whole rear end?
Rescue Tower
You can change it. I think Eaton's true track can be dropped in without setting up ring and pinion again.
