I have a 2012 Ram 3500 4WD Crew Cab ST DUALLY (DRW).
I bought it used with 140,000 miles.
However, after spending almost 3 days trying to match up the 3 REAR MAIN driveshaft U-Joints for a DUALLY (DRW)-
Come to find out my driveshaft calls for SINGLE Rear Wheel U-Joints (SRW)
Is this normal or did someone put a different driveshaft in my truck at some point?
(I rebuilt both front and rear driveshafts using my home made horizontal hydraulic press =
A 1.5 ton bottle jack and a piece of a 20 inch wide "I" Beam.)
(Had to use a grinder to cut out part of the old Rear shaft joints...)
Automotive tire Road surface Asphalt Motor vehicle Bumper
Automotive tire Gas Cannon Cylinder Automotive wheel system
Automotive tire Asphalt Floor Gas Motor vehicle
Super Moderator
In your search are you showing the parts for a diesel and not a gas model?
Yes. At several places (Rockauto / Oriley's / Autozone / NAPA / etc. - we were looking for the exact correct DRW truck that I have and all of the different brands and styles for DRW u-joint X's without the caps would not even fit into the yokes.
But the SRW ones worked perfectly...
Here is what I believe I have as u joint numbers
Moog 295A rear, two piece driveshaft uses three (3)
I have a 2005 DRW two piece driveshaft and they fit, just lubed them before the chilly weather
Have you tried calling a driveline shop? Maybe they would have some info
I have the SAME truck and I just replaced mine last month... 74081485 GM Dodge Rear Driveshaft / Front Axle AAM 1485 U Joint | eBay. Stock was low everywhere and ebay had all 3.
Mine took the AAM 1485s... shorter than the 1480 joints for Spicer. They came with copper colored snap rings and I had to grind .012" off of each one, no biggie. But I got it done and the shafts run smooth.
I also used a 6" disc to cut the crosses out so I only had to drive out one cup at a time... damn rust!
My carrier bearing went at 120k.... check your good.
I got them all done.
2 Moog's and 1 Spicer in the front axle (forget the numbers...)
The rear took 3 Spicer's 5-3206X
