I was wondering if anyone could tell me......how much play there is suppossed to be in the rear drive shaft? when in park, on level ground, without any tension on the shaft, I can turn the shaft about 3/8 of an inch. i am noticing a clunking noise when i stop and go. all my U-joints appear ok. just trying to narrow down my search. also may need to look at my brakes and make sure everything is tight there. If you can.....someone PLEASE HELP!!!!!! Thanks. By the way, it is a 2 pieced shaft with a carrier bearing>
