I was thinking of going to rancho shocks the other day. Checked with Revtek on shock lengths they used on their 6" lift. Bumped them against Rancho's shock lengths(rancho only has 4" lifts and shocks to match) and Revteks shocks are almost 3.5" shorter than rancho's. I unbolt my rear shocks and took pics of the revtek shock fully extended. SEE PICTURES IN 6.7 PERFORMANCE PARTS DISCUSSION under same title. Sorry i could not get them to download twice. Rear shock extends barely 2" past the attachment. Called Revtek and they treat me like i am an idiot so i figured i might as well let everyone else know since they are telling me their kit is correct and nothing is wrong because nobody else has called in. I didn't figure when i installed the lift that i needed to check behind a company that makes the lift to make sure they sent me long enough shocks.
I lifted from the frame on my truck only 3 inches and the shocks are fully extended and the tire is still on the ground, not to mention that the shocks are blown already probably from bottoming out. If you have a REVTEK lift unbolt the bottom mounts and extend the shock out. Number on the rear shock is 5248.
