1 - 3 of 3 Posts
Im looking at getting one of the two in the 150 version, is one easier to install than the other? Ill be doing it by myself and I dont know how my skills are so if the raptor is a lot easier, thats the route Im going.
both are similar, but the Raptor you don't have to install the dray straw w/ either kit. also the raptor still runs through the stock filter housing, the only thing i would suggest if your gonna go the Raptor route is to upgrade the size of tyhe line going from the filter housing to the pump. this will allow more fuel flow to the pump.
kyle
here are links to each install manual
http://www.xtremediesel.com/manuals/pf/Raptor Dodge 150 '03 - '04.5 _5.9L_ Install Manual 2408.pdf
http://www.xtremediesel.com/manuals/PureFlowDodgeIn.DOC
Go with the airdog system all the way. better filtration and the air separation is important to your engines performance. easy install and lifetime warranty makes it hard not to pass up.
plus you eliminate the restrictive stock filter housing all together and run right to you injection pump direct.
john:thumbsup
1 - 3 of 3 Posts
