1 - 4 of 4 Posts
i have a few questions on the raptor lift pump before i buy. which one do i need the 100 or the 150gph. its a 01 cummins with cold air intake, 4" exhaust i plan on eventually putting on a quadzilla adrenaline but nothing after that. i heard the 150gph is louder than the 100gph?? is this true. also i wanted to do the big line kit from filter housing to vp44. has anyone built there own big line kit?
They are pretty much the same price, but they really aren't too loud. I have a friend with the 150. You can't really hear it after you start up. The 100 would be all you'd need, unless you plan on making 550+HP.
don't know about the sound of them i went with the 150 because of future plans with it. i built my own big line kit from the filter to the ip. cost me $12 total in parts. all i did was take one of the banjo fittings to a local hose shop and matched it up to a fitting that came out as a -8 jic fitting, then i got a 90 degree elbow with a barbed hose fitting on the end, pushed on some 1/2 inch lines and good to go!
You own a Cummins and you are worried about your fuel pump making noise? :rof
1 - 4 of 4 Posts
