I have been through two pumps in 3 weeks, pressure drops ramdomly and the other leaked fuel. Now I just put the new on on and it drops to 10psi give or take when you start the truck, then it goes up to 18psi and works like a charm. Why does it drop pressure like that everytime the truck is started? It only happens once when started, other than that it holds psi good.
i dont have that problem, theres a screen on the pump where the line from the tank comes it might be clogged, mine wouldnt hold pressure when i got it and purflow told me to pull the pressure regulator out and there was some stuff out of the bottom of my tank caught up in there that got past the screen, hope this helps
The truck primes and starts easily, it's after it is started and idled for like no more than a minute it drops psi to 10 or lower. Then the pump makes a noise and psi is back up to normal and fine from there on out.
how hard was it to pull the regulater out of the pump ctd24valve? Is there a bunch of crap to mess up or is it pretty simple.
