1 - 4 of 4 Posts
Hello Doods, I am done installing my Raptor100 BUT the fuel quick Connect Wont Connect..I called the dood at Pure Flow and he said I need a quick Connect tool( Well I am blowing fuel everywhere and miles from any shops that might sell a quick connect tool)..I am thinking maybe they should have mentioned this..anyways anyone have any suggestions? Also anyone know what a quick connect tool looks like? I cant run the truck right now...Thanx..G
Discussion Starter #2
Thanx Doods!!!
The quick connect should just push on until they click. It's usually removing them that requires a tool. Not sure about the 3rd gen trucks but the second gen leaves behind a blue connector tab on the line that needs to be removed. If yours did, then you will need to cut that off before installing the new line. Not sure if this will help, but thought I would chime in.
I appreciate the help I ended up having to just use hose and clamps..its easier and guaranteed
1 - 4 of 4 Posts
