1 - 12 of 12 Posts
My GPS just randomly goes out. As in no signal. Zero on the GPS bars. Map rotates and follows the truck but of course it's direction/location is wrong. Map is in the area unless i drive far enough that it is going the opposite way. This issue happened months ago and mostly did not happen for awhile but it's back all day today.
I can't make heads nor tails or it. Can't take it into the dealer, it'll work tomorrow and for who knows how long.
Anyone else have this issue?
Speedo is always correct.
Why wouldn't the speedometer be correct? It has nothing to do with the gps.
As to the nav randomly not getting a sat signal, could be mechanical like a bad antenna connection or it could be a software issue.
Maybe he's talking about the speedo on the GPS?
That's what I assume.
However, the Nav unit would still need a signal to display the speed, as it's computing speed by time to distance.
I'm thinking there are two connections for the antenna, the rear wall which would suck to dig into and behind the headunit?
still not working this morning.
I believe that the cable for the antenna runs down the A pillar then down behind the dash to the head unit. I doubt the connection issue, if that's what is wrong, would be at the antenna end, so I would first check the connection on the back of the head unit.
If it's a software/firmware issue, that would be a tough one to diagnose on your own. Probably would have to pull the head unit and have it checked out by one of the companies that refurbishes them.
Discussion Starter #8
This truck did not have factory NAV. It had the 8.4 but not the software. I bought the software from FCA and put in the code. That brings up a whole different can of worms.
I too think it's software related.....the thing that disappears also is the 911 service. Service something to 911 not available prompt. That pops up on the screen several minutes after the gps is lost.
I also have not done the uconnect thing to my phone or whatever provider. I want to say this issue pops up after I bluetooth connect my phone. I'm not positive but they both seem to be real close. I do not use my bluetooth connection hardly at all.
Discussion Starter #9
I've master reset the unit, no change.
The GPS has been out for a week now. No signal. It knows N S E W and rotates but the map is in Texas right now after a master reset. Called Chrysler, they said take it in.
I pulled the head unit, checked the Ant/GPS and all that, all tight. Pulled the GPS lead and put another GPS antenna in and no change.
Looks like dealer time.
I did notice, that whenever the GPS is working, the Uconnect 3G is lit up. This has always corresponded with the GPS working. It was semi working the day I got the truck. I have not had that portion of service. I did in fact start to play with the uconnect one day when it was lit up in my driveway. This was about when or when the GPS signal loses started. I'm not sure how to proceed with finalizing that procedure of it it's necessary.
I don't know if this is the same problem, but in the first year that I had mine,occasionally on startup the whole 8.4 screen would be blank. After t he truck warmed up it would usually come back on at startup. I took it in several times and they reflashed it, but it still kept doing it, finally they sent me a thumbdrive which I loaded myself and this cured it. One time the map froze like your talking about, but once I downloaded the thumbdrive I have never had another problem. Hope this helps.
Has anyone found the fix? Ive searched many sights and no one ever states what the fix is...maybe there isnt one??? Just bought a 2014 Ram and GPS worked a couple times then I get no signal and I'm not even close to where I am.
Have you had any developments in this problem?
Many of us have the the same problem. I'm determined to figure it out. I have been testing components in a stepwise method; I've replaced the sharkfin antenna, bypassed the factory wiring; installed an aftermarket GPS antenna, and everything keeps pointing back to the headunit. I admit I'm puzzled. I'm working with a company call Infotainment and they seem to think that there was an OTA update that's causing the problem. I have a new headunit enroute to me now. I'll let you know how it works out.
Paul
1 - 12 of 12 Posts
