1 - 1 of 1 Posts
Overview:
2003-2012 Dodge 2500/3500 2.5" Suspension System levels out your truck and offers you both incredible ride quality and performance. This kit is engineered to give you a much improved ride both on and off-road. Our Stage 1-5 System is comprised of our Dual Rate Coil Springs, 3.5" Polyurethane Bump Stops, Sway-Bar Drop Brackets to compliment the additional travel, and all required installation hardware.
Wheel & Tire Fitment Info:
OEM Wheels & Tires: Yes
Aftermarket Wheels: 8" Wide Wheel With 5" Backspace
Aftermarket Tires: 33" Tall Tires
Larger Tires May Fit but Fender Trimming and Modifications will be Required.
STAGE 1
System Components:
212500 (QTY - 1) - 2003+ Dodge 2500/3500 2.5" Coil-Spring Kit
216521 (QTY - 2) - 03+ Ram 2500/3500 (2.5" Lift) 2.0 Aluminum Series Front Shocks
216522 (QTY - 2) - 03+ Ram 2500/3500 (Stock - 3" Lift) 2.0 Aluminum Series Rear Shocks
STAGE 2
System Components:
214030 (QTY - 1) - Dodge Front Adjustable Pan Rod Bar Kit
STAGE 3
System Components:
214020 (QTY - 1) - Dodge Front Adjustable Upper Link Kit
STAGE 4
System Components:
217800 (QTY - 2) - 03+ Ram 2500/3500 (2-3" Lift) 2.5" V.S. Series Remote Reservoir Front Shocks
217701 (QTY - 2) - 03+ Ram 2500/3500 (2-3" Lift) 2.5" V.S. Series Piggyback Reservoir Rear Shocks
STAGE 5
System Components:
214025 (QTY - 1) - Dodge Front Lower Link Kit
If you have any questions please feel free to contact me.
Thanks
Todd
1 - 1 of 1 Posts
