1 - 14 of 14 Posts
hi guys im new here can anybody help me with code P051B ? i just deleted my truck yesturday i have close to 23k milage and im realy dissapointed abut these code i just lost my warranty doing these and these just poped after i deleted with ez lynk gdp tuning ..... please help! thanks!!
Did you delete the CCV too?
That code is for the crankcase pressure sensor out of range, so if you deleted the CCV but the tune didn't account for it then that could be the issue.
Relax, there's always a few kinks to work out after a delete if you have never done it before. You probably just unplugged that sensor by mistake when doing the delete, oops. I did that too with one of the sensors, can't remember which one.. Simple, plug it back in, clear the code.
No reason to worry about warranty at this point, that's moving backward. Its just a sensor. You deleted, now you are the warranty. If you weren't ready to accept that responsibility, you weren't ready to delete.
If you continue to have issues, call your tuner and Im sure they will take care of you. Good luck.
Yeah, but he stated in the duplicate thread that he checked to see if that sensor was plugged in and it was.
I see.. had no idea there was a duplicate thread. Just threw that out because it's always important to start simple. I'll let this ride out and live in the other thread but thanks for the response. Personally I'd be on the phone with the tuner first if it popped up after the unlock and tune.
· Cummins Addict
i had the same issue easy fix install the stof program and it will be fixed
You had the same issue? No kidding. You realize this is your thread, right?
· Admin/Mod
Merged the 2 threads, reread and you might get an answer.
Reactions: URDiesel
1 - 14 of 14 Posts
