TS MP-8, Edge EZ for the 04.5-05, Power Puck, Dr. P predator, and quad has a pressure box but the name is escaping me...is there a box that gives you rail pressure but no timing
thanks wes:thumbsup
All Quad chips do timing. They can be modded for pressure only or with X2, a pressure only tune can be downloaded.TS MP-8, Edge EZ for the 04.5-05, Power Puck, Dr. P predator, and quad has a pressure box but the name is escaping me...
MAP signal cannot affect timing...Most advance the injection timing slightly by altering the boost pressure signal to the computer through the MAP sensor. Or so I've been told.
Yeah that is what I was trying to say. For whatever reason quad box names confuse me.:coocooAll Quad chips do timing. They can be modded for pressure only or with X2, a pressure only tune can be downloaded.
On the the thoroughbreddiesel site under MP-8 FAQ's it reads "since the map sensor thinks it is at different boost level it will add injection timing accordingly".All Quad chips do timing. They can be modded for pressure only or with X2, a pressure only tune can be downloaded.
I think that is referring in a very confusing manner to the boost fooling of the MP8, the boost fooler makes the engine think it is as a higher(or lower, I honestly forget which one:thudOn the the thoroughbreddiesel site under MP-8 FAQ's it reads "since the map sensor thinks it is at different boost level it will add injection timing accordingly".
When you add rail pressure it increases timming slightly, so any rail psi box increases timming just not enough that it should be a problem.On the the thoroughbreddiesel site under MP-8 FAQ's it reads "since the map sensor thinks it is at different boost level it will add injection timing accordingly".
As said above, IMO, the EZ is a great choice. :thumbsupi was also kinda wondering about the edge ez
