1 - 15 of 15 Posts
Ok I've been wondering here lately where should my rail pressure be at idling it goes 4.2 then jumps to say 4.7 is this a safe operating range
Sent from my EVO using Tapatalk 2
:agree2::agree2::agree2:
Mine at idle is about 6 to 6.5
I still have pump on the fuel canister. The reason I was asking is trucks been acting funky got on the interstate and wot felt nothing spitting and sputtering and rail dropped to 1.5 and 1.8. Brought it back home or more like limped it home and next morning it was fine
I also did a 350 mile round trip and came home and was leaving again on interstae
sounds like lift pump time...do u have a low fuel pressure gauge? maybe u should jump on the raptor 150 thats for sale here
I'm wanting a 150 but isn't there two different styles frame mounted and in tank right which is better and what all needs to be done
Your Delightfully Ginger Kentucky President
Good idea to check the PRV as well. A rail cap on temporarily is a quick and easy way to find out.
Discussion Starter · #10 ·
Insight me on orc and rail cap
only diff would be a draw straw. since your stock lift pump is canister mounted like mine was its a simple plug n play...well sorta, removing the factory quick connect at the tank was a biatch.
Discussion Starter · #12 ·
Ok so which is better in tank or frame mounted
any aftermarket perf pump will be frame mounted. the in tank came in like 05 to fix a weak canister mounted pump like ours. if u had a prob within warranty the dealer retro fitted an in tank. be thankful u dont have an in tank cause adding a airdog or fass would be more difficult.
Discussion Starter · #14 ·
Ok then good
my 04.5 idles 7k solid.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
1 - 15 of 15 Posts
