Heeeeelllllloooooooo?
That is going to cause some rail pressure issues if that is happening at an idle. Looks like replacement time. Check TCDiesel for a much more reasonably priced PRV.PRV is bad filled with fuel immediately
While the whole rail gives u a pressure sender. And the relief valve IIRC. Little more money it is up to you. Personally I would just get the prvWould I be better off buying the prv from TC or the whole rail from genos?
prv stands for pressure relief valve. if you get a spike in rail pressure, it opens to avoid damage. it can sometimes become worn out and lead to other issues as far as not maintaining and or making correct rail pressure.watt is the prv
No.watt is the prv
I really thought he meant "what" instead of "watt"No.
A watt is a measure of electrical energy transfer.
A PRV is is mechanical device to limit pressure.
They are not equal or comparable.
