Discussion Starter · #1 · (Edited by Moderator)
I got a 2018 dodge 2500 6.7, I’m still learning about diesel trucks and some mods.
I just added a 5in exhaust on it with the raceme ultra tuner and out the settings at default settings. Does the 120hp effect the towing when it is needed or should I go lower on the HP? I know you don’t want to gun it a lot because it can do damage to the turbo and mess up the transmission after awhile. Not trying to do a lot of stuff to it. Just want it working for a daily driver truck.
When I tow I always run the stock tune. Its more than enough power for anything under gross combined and won't tear up our driveline. Around town unloaded I would stuck to something in the 40-90hp range myself if the rest of the truck is stock. A little more 'pep" and a tiny bit better MPG, but even that can cause damage if you don't drive it right.
We don't talk about deletes here, fyi.
SuperModerator
Read what has been posted already.
Reading the Sticky Discussions that say "READ Before Posting" also helps.
Opps.
And, Welcome to the forum.
I tow my 8000# travel trailer on the 120hp tune. I don't lay into super hard up the hills, and like to keep my boost around 20psi. I tried the lower HP tunes and found my fuel mileage was poor
Sent from my SM-A705W using Tapatalk
