1 - 3 of 3 Posts
ok so i bought brand new fenders to put on my truck and they do not cum with fender welds so i take the bolts out of my old fenders and it turns out the fender welds are stuck to old fenders so i couldnt take them out. any one kno how to get the fender welds off? plz help
They make a spot weld cutter that you chuck up in your drill to cut the welds. You can use a regular drill bit but you'll have to drill thru both panels while with the cutter you only work the top panel so theres no hole to fill later! Hope that helps.
Spot weld cutter is my choice also. Avaliable at professional body parts store or perhaps a can paint supply store..
1 - 3 of 3 Posts
