1 - 2 of 2 Posts
so my trans has a transgo shift kit installed in it, but looking to swap it over to the tfod-3 manual kit from transgo, will i need a new valve bodie to do this with or can i still use my one with the old kit in it? i know can just go buy like a suncoast mvb witch i do plan.. this is just a cheap winter test.. rather see if i like it for $120 then spend $700+ and decide i hate it.. let me know guys thank you!
if you daily drive it i wouldnt suggest a full manual valve body. as for will it work, call transgo and ask. they will know better then anyone.
the reason i suggest not going full manual vb on a dd is that you WILL wear out the stock shift linkage extremely quickly.... and the replacement parts arent fun to install or cheap to buy....
1 - 2 of 2 Posts
