1 - 3 of 3 Posts
I Finally got to install my Smarty. I am wondering about the settings i see everyone using.I selected Software #5 for my truck. Is that all i do to install?
How do i adjust the boost, etc ...
I see you got twins. Bout the only way to adjust boost is clamp wastegate hose or adj. the wastegate actuator. If you have the revo s/w, you can adj. timing, rail pressure, torque management, and wastegate, on or off.
MADS Electronics - Smarty - CaTCHER - Download. New s/w is available to download, and little more info on the revo s/w.
Will the computer throw me a high boost code when i get to to 32psi. i was using a boost fooler and have taken it out for the smarty install. And yes i can adjust my waste gate manually.
1 - 3 of 3 Posts
