Hello everyone, the other day I got my tank/toolbox back from being sand blasted/painted. The tank I have is not an official auxiliary tank, I think it would be classified as a transfer tank. It already had a 1/4" drain port on the bottom left so I got the RDS gravity feed kit and installed that. I went to Napa and got a 1/4" petc0ck and 5/16" barbed nipple because the RDS petc0ck is 3/8".
I'm pretty confident my plumbing to the filler neck with the ball valve is correct but I'm not getting any fuel transfer. After I did some reading I realized my tank has no vent ports for this setup. It just has your typical bulkhead on top with the push and twist cap, the first couple of times I took it off I could hear either vacuum or pressure escaping. Then it has the other opening on the passenger side for a transfer pump. I'm thinking the easiest way for me to put a vent in is take the screw in cap (pictured) out then drill and tap it for a rollover safe vent. I was thinking I would silicone the threads and hope for the best.
If anyone has a part number from napa or advance auto for a good vent valve to use I would appreciate it.
Master of Mayhem NASFIG
My aux tank has a self vent cap set up that allows venting and wont spill fuel. Seen some just like it at tractor supply.
Must be I have a different problem then because I have the same kind of cap already on it...not sure why I would here a pressure change when I remove it though...I'm thinking maybe them painting over the whole cap may have clogged it up? I'll just go get another cap tomorrow and try that.
x2 rpage. here is what to do with the transfer side. make them both the same, fill from either side.
Reactions: Rob66
Well I'm all copy catted up :thumbsup:...
Ended up my routing to the ball valve wasn't quite right, she's flowing now, thanks for the help!
