Hi!,
I am installing gauges and was wondering the prefered location to plumb The boost gauge into the intake on my 91.:confused:
Thanks,
Dan
you dont have to drill a hole there is a allen key nut right behind the fuel lines i believe, you just unscrew then you screw the boost line into with the supplied with your gauges
Yep, its on the side of the head below the intake area a little forward of center.
Thanks, found it.
Thanks for the help. Found it and have the gauge all plumbed in.:hyper:
and it WORKS:thumbsup :thumbsup
Dan.
What kind of boost number are you getting?
Boost
Paccool,
Max is 18lbs. I did not notice at what rpm, but I will check as I just installed a tiny tach. Also installed a mech. oil preshure gauge, Hot idle 35psi / cruise 55psi. Also am installing a EGT pyro, installed it post turbo, moving it to pre turbo.
Dan
18psi sounds about right for a stock engine, maybe a little above.
Daniel
