question about stacks
865 Views 10 Replies 9 Participants Last post by  BigHemi04
does water collect at the bottom of your exhaust when it rains or snows
1 - 11 of 11 Posts
· Just Another Slow VP
i got a set of aussies and they dont collect much. but if ya got a miter or flat cut stack i can magine they collect some water.
I had the same question. and I was told people just put a vary tiny hole in the bottome some where and that fixes it.
Reactions: depcox
well ya can either drill a small hole for water to drain, or get a few maxwell house cans and put em over em when it rains.
but no. its not goin to be a problem if water gets in em. just spit black droplets out the stacks
Reactions: depcox
i just drilled a hole right at the bottom of the 90 pipe for rain but snow i dont bother covering it. its so cool to watch the snow blow out when you start it :thumbsup:
Just make sure your windows are closed when you start it after its sat out or your arm will be covered in soot. :) As long as you drive it enough though the water is not going to affect the exhuast though. There is enough soot in the pipes that it kinda protects the inside from rust.
this issue is one of the main reasons i got rid of my miter cut single stack. Made a mess when it rained if you couldnt get it covered up and the soot goes everywhere litteraly
1 - 11 of 11 Posts
