I got my two wires ran but kinda at a lost now with my switch. I bought a three pole switch with and led to let me know that it is on but I dont know how to hook up the wires on it. Need help. Here is the configuration of the switch.
Top #3: To Ground
Middle #1: To source (max 10A) or Relay trigger; Power Source
Bottom #2: To the source ( To positive lead)
I just got a regular switch from the feed store and ran two 6 ft wires out of the tow ends of the switch and tapped one wire into the pink wire and the other into the yellow wire on the map sensor. And it worked good.
well the problem i got is that i already drilled a hole in the dash panel :banghead: so i have to find some way to make it work. My wire colors a different though i believe cause i used and orange wire and grey/red just cause of different years. Also i do have a power puck on mine so i dont know if that would make any difference with the wiring
weeeeeelll, ya could run a lead to the battery, then, tap that onto one of the leads goin to the switch, maybe that'll work
1 - 11 of 11 Posts
Dodge Cummins Diesel Forum
