Yeah 35 is the max "cool" air for a stocker. When I had my Edge I could hit a tad over 40psi also. It does have a boost fooler built in.yeah the edge has a boost fooler built into it, i can hit 41psi as well but from what people say on here anything past 35psi with a stock turbo is just hot air.
There is no option on mine. I ran it for over a year and you should have no problem at all. :thumbsup: I doubt you are hitting 40+psi many times a day anyway.is there a way to turn it off if wanted?
Yeah it seems like some people claim their edge is off and others don't have a single problem with it. :confused013: Like I said both EGT and boost are SPOT on exact. Even though the Edge is tied into the map sensor and my gauge is hooked into a "boost bolt" that reads straight from the intake. two different spots, two different methods, exact same reading.:thumbsup:I saw you were running a mech. gauge as well...that's part of why I posted. I hoped you'd chime in. I don't have a mechanical to compare so I really don't know if mine is off. I was just surprised at how high of a boost reading I was getting. I think I may try to get another gauge installed...
