OK here's the deal two days ago I installed Sdx 7x12 with. 15 lift sac injectors now after I let outta the throttle and push in the clutch the rpm will drop to almost 500 rpm go up and back to around 700 rpm then back to idle y is this any help would b great
Learn to cope with throttle movement.
· Master of Mayhem NASFIG
well yea thats gonna have something to do with it along with the injector, but the only way to fix it is to get a bigger vp i believe. You cant change the idle due to the computer control of it as far as i know. The truck is sucking more fuel at idle then the ecm is used to stock.
OK appreciate it I mean it doesn't go into lope mode just does that then goes to normal idle but I sent my stock tubes back also
