Mine is 2WD. 1997 3500 extended cab. Not sure how the auto cruise transfers over. Do you run a fuel plate on yours? If so what size are you running and timing. I think I saw your truck on youtube. Thumbs up. Thanks for reply!My conversion from a NV4500 was seamless. It just worked. Is yours a 4WD or 2WD? You need a vehicle speed input for the cruise to work. If you have a 2WD I suggest you research Dakota Digital.
Two other questions for you.Yes I have a custom plate with 15 degrees of timing. There is nothing to "transfer over". Wire in a Dakota Digital signal interface for the speedometer and drive it. I did have my truck featured by a u-tuber.
