1 - 16 of 16 Posts
Better check and make sure Map sensor voltage is the same on those years.
Xzillaraider for 2nd gen is 120hp/325fttq.
I think the quad fuels to a little higher RPM.
If quad still has them available then yes, you can get a new harness and it will work fine. It is a fuel only box and does not do timing. Stack that thing with a XZT+ and you'll have better low end and top end than an edge comp.
there are two different model xzillaraiders. one is a 60hp chip and the other is the 120 hp. when u hook it up and turn the key on it blinks three different colors, depending on the sequence that is the model u have. u have to look in the install manual and it will tell u which colors mean what.
1 - 16 of 16 Posts
