1 - 2 of 2 Posts
In case some of you haven't seen we now have Adrenaline updates out that are XP, Vista 32, Vista 64 and Windows 7 compatible.
Also in this process we have made the updater more robust and the driver install should be better and more complete than previous updaters.
I will say that occassionally the Vista 64 does not quite install correctly especially if the machine has not been rebooted recently but, the fix is much simpler now than before.
If you have problems with Vista 64, reboot the machine and after it is restarted go into the hardware menu, usb devices and then plug your box in, right click the device and select uninstall drivers. After this close that down and start over with your update and the driver should install correctly.
We did not see this very often and it seemed to be only on particular machines but, microsoft offers very little support for Vista 64 and they openly admit it is a mild disaster! :S:
Worse case scenario if you need help please contact tech support but, these are much more robust than ever before.
XZT+ and M3 users will have more updates available in the near future as well.
Quad, is this something you can get by email or off the site? some of the newer guys may want to know where to get this :thumbsup:
1 - 2 of 2 Posts
