1 - 20 of 110 Posts
Western WA President
Got the permanent site up finally.
We have both Adrenaline and XZT+ tunes along with download instructions and manuals, and the pulse monitor update.
It's nothing fancy, just a folder structure and download list with direct links to each file for download.
http://scotch.unixmail.org/quadtunes/
Thank you to everyone who made this possible. Couldn't have done it without you! :thumbsup:
Edit: Updated the URL as the old domain name had expired.
Discussion Starter #2 (Edited)
copied from quads cached website should be the same for 1000 and 3000 tunes:
07/29/2008
Note: For these tunes the .NET framework ver 3.5 is required before these updates will work properly. Download ver 3.5 for free here: .NET framework ver 3.5
The updates dated 07/29/2008 and newer will work on all XP and Vista machines and laptops.
01/06/2011 - Any files with an update date of 01/06/2011 or newer are Windows Vista and Windows 7 compatible.
Quadzilla 98-02 Adrenaline Module Updates - Aggressive
File Name: ADR2_2000
UPDATED: 01/06/2011
Models: DADR9802
Software Version: 20090925
Feature Code Enabled: ADR2_2000
Features:
*Aggressive 10 Power Level Tuning
*No Other Features Enabled
*Works with ver 2.0 Adrenaline Boards
File Name: ADR2_2001
UPDATED: 01/06/2011
Models: DADR9802
Software Version: 20100522
Feature Code Enabled: ADR22001
Features:
*Warm Up Mode set for 140 deg
*Control Pod will display flashing PL00 while in warm up mode
File Name: ADR2_2002
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22002
Features:
*Warm Up Mode set for 170 deg
File Name: ADR2_2003
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22003
Features:
*Hi Idle Enabled for 1200 RPM
*You must be in PL00 in order for High Idle to Enable
*2 minute idle time required for High Idle to Engage
File Name: ADR2_2004
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22004
Features:
*High Idle will Engage after 2 minutes while the module is in warm up mode regardless of the PL setting you left it on
File Name: ADR2_2005
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22005
Features:
File Name: ADR2_2006
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22006
Features:
*Turbo Timer set for 3 minutes at shutdown
File Name: ADR2_2007
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22007
Features:
*Turbo Timer set for 300 degrees at shutdown
File Name: ADR2_2008
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22008
Features:
*Turbo Timer set for 3 minutes at Shutdown
File Name: ADR2_2009
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22009
Features:
File Name: ADR2_2010
UPDATED: 01/06/2011
Models: DADR9802
Feature Code Enabled: ADR22010
Features:
File Name: ADR2011G
UPDATED: 04/08/2009
Models: DADR9802
Software Version: 20090407
Feature Code Enabled: ADR2011G
Features:
File Name: ADR2012G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2012G
Features:
*EGT De-Fueling set at 1250 deg
File Name: ADR2013G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2013G
Features:
*EGT De-fueling set at 1250 deg
File Name: ADR2014G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2014G
Features:
File Name: ADR2015G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2015G
Features:
File Name: ADR2016G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2016G
Features:
File Name: ADR2017G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2017G
Features:
*Turbo Timer set at 3 minutes
File Name: ADR2018G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2018G
Features:
File Name: ADR2019G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2019G
Features:
*EGT De-fueling set at 1150 deg
*Designed to be used with large injectors to prevent EGT overrun
*Keeps EGT below 1250-1300 when used with various makes of large injectors
File Name: ADR2020G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2020G
Features:
File Name: ADR2021G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2021G
Features:
File Name: ADR2022G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2022G
Features:
File Name: ADR2023G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2023G
Features:
File Name: ADR2024G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2024G
Features:
File Name: ADR2025G
UPDATED: 04/08/2009
Models: DADR9802
Feature Code Enabled: ADR2025G
Features:
:bump: link to the download site has changed. New link is in the original post :thumbsup:
so I have a quad adr box that says ADR1002 55402 on the sticker. what tunes will work for my quad?
when I plug it in, the version says 20090925 so would I use only the tunes that are compatible with that version?
any of the adrenaline tunes.
In the adr1000 or adr2000 tune categories?
So any from the adr1000 or adr2000 tune categories?
OK, I see there are many more tunes on the site than there is listed above. Do the tunes follow into a couple different categories? Sorry for all the questions, I just got mine.
Discussion Starter #9
any adr1000, adr2000, and BETA will work.
adr1000 just means stock like tunes for the module the different numbers after the 1 just indicate the different modes pre-enabled on the box like shown in the second post in this thread...
adr2000 makes the box fuel more aggressively than adr1000 settings.
then in the beta section there is adr3000 which fuels more aggressive yet.
from there you can go to the adrTorq which gives a stronger bottom end and torque for sled pulling, and there is adrComp which is the most aggressive tune for racing and really putting you back in your seat.
there is also the dyno tune which is specifically for running on the dyno. it is very rough and not road friendly...throttle is too jumpy and will surge badly on the street. so basically it is only good for dyno queens and nothing else.
the beta tunes are not very "average user"/street friendly on higher power levels. So don't go whining when you run a beta tune and your truck has jumpy spots in your accelerator pedal that makes your truck feel like it's surging. (just fair warning)
I personally run the comp2 tune that is in the do not use with PV2 folder...(I don't have a PV2, and it is an older tune from years ago) I also have it heavily customized via custom tuning in my pulse monitor to fit my needs since my truck is at a moderate modification level.
COMP2 is for PODs & PV1s. I BELIEVE that ADR2COMP will work with the PV2.
Jig, you might as well remove the IQUAD for IOS APP, as I spent over 16 hours trying to hack it. No luck whatsoever. I shall NEVER buy an APPLE device.
Ed
I can't get the 2.3.0.0 to download into my pv2. I've tried 2 pv2's and 8 computers. Followed the instructions to a tee. Can anyone help me out?
Discussion Starter #12
do you have a 4k box? 2.3.0 is only for use with adrenaline 4k boxes...
if you don't have a 4k box, don't bother with it.
Discussion Starter #13
Ed
done.
it is still in the all-in-one zip though...not even going to bother with that...too much work :hehe: i'm lazy :sofa1:
Discussion Starter #15
it wont display properly in custom tuning without the 4k flash on the pulse.
with the 4k flash it will show the correct fuel stretch.
just follow the updating documentation on the site.
So it will still rev to 4k? I followed it. It just keeps saying commander not found. I'm gonna try a different chord I think, I mean couldn't hurt right.
Sorry for questions, I am new to this quad tuning stuff. So the further you go down the list, the more aggressive the tune gets?
If you have a 4k box then you can only use 4k tunes. which I dont think you have from what you said above.
If you have a standard box then you can run any of the tunes other than the 4k. beta are the most aggressive, 2000 are the best of both worlds and 1000 tunes are the safest to run egt driveline etc etc/
My truck is mildly built via sig. What would be the best for me you guys think?
1 - 20 of 110 Posts
