Hey,
I just bought a used Quad Adr. with iQuadBT. It came with nearly everything, and all looks good. I've updated it with standard V2 base tune.
So, it's adr-1000 with all the adapters for the 98.5-00 trucks, and I have an 01. I've read me78569's "Quad Tips and Tricks" thread, https://mopar1973man.com/cummins/ar...ricks-24v-vp44-cummins-tuner-programmer-r444/. But it seems a bit dated, and doesn't seem to help my situation. So what I want to do is make my own Map adapter, and I was hoping I could use the one I have. I need to know what plugs the 2001 Map Sensor uses. And then how to wire it to the existing 98.5-00 Map adapter that I have. If anyone can help?
Also, at the Data Link on my truck, there are 3 wires coming from the main harness. Two go to the plug, a black w/white stripe and yellow w/green. The other wire is a yellow w/blue stripe and is broken. Does anyone know what the broken wire goes to? I've attached a picture, the red arrow is pointing to the broken yellow w/ blue stripe wire. I know its hard to see but the Data Link it next to it, on the left.
Thanks
Discussion Starter · #2 ·
Anyone have any clue as to what type of plugs the 2001 Map sensor uses?
Or what the broken wire might go to?
Call Quadzilla and just buy the right adapter, you dont want to chop up your harness.
Mopar1973man.com has all the pin outs in the articles.
I've asked Quad, they keep giving me the run around. I'm not messing with the main harness, just the Map harness. I have Quad part number D-7225-2, the Map adapter for the 98.5-00 trucks. I just want to replace the round connectors with the right flat pin connectors, I just don't know the right connector part numbers.
Products - ADRENALINE - Adrenaline Accessories - Page 1 - Quadzilla
There are adapters for 2001 and for 2002
If you really want adapt it yourself then everything you need is here
98.5-00 wiring
https://mopar1973man.com/cummins/ar...ngine/electrical/2000-engine-wiring-map-r391/
2001 wiring
https://mopar1973man.com/cummins/ar...ngine/electrical/2001-engine-wiring-map-r392/
2002 wiring
https://mopar1973man.com/cummins/ar...ngine/electrical/2002-engine-wiring-map-r393/
you will need to know if your truck has the 01 or 02 plug, don't assume use a multimeter and pin it out to find out.
Alright, thanks for that.
So does anyone know about that broken wire?
