1 - 4 of 4 Posts
I think I might have a leak in an intercooler boot. On the stock setting I can get 28 lbs. of boost, and on the 100hp setting I can only get 30 lbs. of boost. Any suggestions??? Is there a way to test the boots without taking them off to inspect them?
Thank ahead of time....
Jay
On the 100hp setting, I am seeing around 40psi boost pressure. I would just check all the clamps on the boots to make sure they are tight. They tend to loosen up over time.
I was using the factory loaded settings for the X2. I was under the impression that there would be boost fooling built into the 100 hp setting. I also contacted Quadzilla and they recommended downloading a newer program, which is easier said than done. My computer did not want to work with their programs. I'm going to try it all over again. And see what happens.....how much of a difference would a dirty air filter make?
1 - 4 of 4 Posts
