1 - 4 of 4 Posts
any one that has these let me know how the truck turns off, just put mine on 20 min ago and when i cut truck of i guess the quad cuts the power to the rail press sensor. when it shuts off you feel it then it winds down.?????
We do not have any contact with the power or ground side of the rail pressure sensor.
If you look at the harness you will see that we are simply "tee'd" into the signal line.
why does it shut off diff after i put it in the truck??
bump........
1 - 4 of 4 Posts
