1 - 9 of 9 Posts
what have you been using to lube them with? mine were very hard to open when i bought it, but some pb blaster got the open, and white lithium spray keeps them opening.
The latches are what i was referring to. When i bought it mine stuck closed so bad you basically needed to climb up and kick them open. Unless the hinges are really sagged out, it could just be that the latches are stuck up with grime. Try soaking them both (top and bottom) with a good penetrating oil, or penetrent plus lube.
the piece that went to the latches from the handle on mine had came off might be your problem but just soaking it in pb blaster would be easier to start off with
· Super Moderator
99 qclb, 325dap, compound. Billet trans, 37 toyo, lockers, winch, 10kw stereo, quadzilla
when mine quit opening i used a second truck and a long bar to pry the doors open. then i replaced the latches and have not had an issue since
Reactions: hmad
Speaking of quad doors, where is the best place to get parts for them? My passenger quad door doesn't open from the inside the handle is messed up.
· Super Moderator
i junk yard all my stuff
1 - 9 of 9 Posts
