1 - 20 of 3346 Posts
Hey gang, since we get alot of questions regarding the Adrenaline I figured maybe we could try to keep it all in one thread for easy reference.
Any comments on the Adrenaline? Special tunes for stacking? Feel free to post for any tech help so members can chime in as well or just give your overall experience with the Adrenaline.
I have spoke with Quad and he said he will check this thread as often as time allows to answer any questions or comments.
Thanks,
James
Discussion Starter #2
Alright, I had BBRam move this into the 1998.5-2002 Performance Parts Discuccion for better exposure.
Lets make this the thread to discuss the Adrenaline as stated in the first post.
Sponsors, no advertising in this thread please. :beer
Banned
I would like to ask about the fuel pressure sensor. What is a part # that is available at the local auto parts store that is working to give acurate readings of fuel pressure? I read it somewhere before, but can't find it now.
i would like to know when the pulse/ adren combo will be shipped :CRY::ah:
Quadzilla is saying the units will ship out on May 5th.
I'd like to know the answer to the fuel sending unit question too. I didn't buy an Adrenaline w/PCM because of push backs on the delivery.
I had a short list that Quad ran off to me one day but I have since misplaced it and can not find it.
Reactions: dhoward
What is Stage 3,I would like to no that
Discussion Starter #10
if you allready had gauges could you run the adren with out the pod?
You are referring to the digital control POD that comes with the Adrenaline correct? You can still use it to control power levels.
Banned
I orderd my fuel sending unit about a week ago and got it friday.. :hyper:
Banned
you still hook the pod up to the comp and you just dont run your gauges like oil/tranny temp exhaust temp or fuel pressure, you will have boost hooked up and you will also use the pod to run your settings while you drive.. the adrenalin is VERY fast when you change to a higher or lower tune you notice the change as soon as you push the button..
has anyone else had a problem with it cutting out? how much smoke is it giving you too...(not that it really matters) ...Just curious
like in the title the truck would not turn off after cooling past 300deg. i was in the house and noticed i could still hear it running. went out with keys in my hand, put them in, turned back on and off no help. put in gear and tryed to kill it. wouyld not die. had to open the fuse box(inside cab) before it would die. the dash still stayed on. so i pulled the adr out from under the hood. i am going to redownload the tune to c if that could be the prob. but this has been working properly for two days now. any help on this would b great. my truk is in my sig. thanks
re; to big r. no cuttin out issues so far. i can shut the road down with the rigt pedal if u kno what i mean. well im lying i can make people hit the shoulder on the interstate. this thing will smoke like crazy. i am stackin it with a tune from Jim Jessup though:thumbsup
Tech Specialist
I tapped into the factory oil PSI sender and my dipricol optix EGT gauge wires for the adrenaline. Oil psi is dead on and pulse egt gauge is 130* high but it works pretty dang nice. Not to mention you it monitors water temp, fuel temp, fuel psi, ECM voltage, engine load %, tps %, boost, vehicle speed, corrected vehicle speed, tranny temp, and a few others. It pulls them from the ECM and seems to be pretty dang accurate.
Will any 240-33 ohm pressure sender work for the fuel pressure or does it have to specifically be a 0-40psi sender? Would the scaling be off with a 0-100 sender? The 0-40 ones are tough to find.
Banned
I pulled a LOW 10 in the 1/8 mile with two wheel drive slow launches... so god only know what I would have got with 4 wheel drive launches I was only on PL04 and im a 5 speed manual.. 70 mph at the finish line.
you think its good enough for a 5 speed truck to pull a a mid 14 in the 1/4? maybe faster?
seriusoly, that would be pretty fast
