Would someone mind explaining to me what a pyrometer measures and where u locate the sender on the engine, I just bought a diesel and am now looking for gagues, thanks:confused013:
97's don't come w/ a pyro...and the pro measures exhaust gas temps, basically how hot the motor is running...
gives James at RSD a call and he'll set ya up w/ anything you need
http://rollinsmokediesel.com 219-851-1195
Ok thanks for that but I am still wondering what is the dif between a egt gague and a pyrometer gague ?m
Pyrometer is a gauge to measure heat, egt stands for exhaust gas temp. Same thing. Try google its helpful.
"Gauges
- The most useful investment you'll want to start with is a set of gauges to monitor certain parameters if you plan to turn up your fueling any. Boost, Pyrometer (Exhaust Gas Temperature - EGT), and Transmission Temp if you have an auto trans. Fuel Pressure is another very helpful one, as fuel related issues are all but impossible to diagnose without one, and everyone has fuel issues at some point.
Brands with the best reputations include: Isspro, and Autometer. There are others of course, but as with anything, you get what you pay for.
IMPORTANT: When installing a pyrometer the best place for probe installation is pre-turbo, in the back half of the exhaust manifold about an inch from the turbo inlet. Intallation post-turbo will give you inaccurate readings, with up to 200º-300º F variation."
The above information was found here. http://www.cumminsforum.com/forum/9...ssion/314312-beginners-thread-read-first.html
Check this out in the tech articles. Pyrometer install.
