1 - 10 of 10 Posts
I posted earleier that I installed a new turbo on the truck today and at idle the EGT's where 500+ and if i just tapped the throttle the gauge would go way over 1200. So, I let the truck sit for 1hr and the Pyro still read 300 degrees, ipulled it out and looked at it, ande everything seems fine, so I went back and looked at the gauge and the needle was just moving up and down ever so slightly but still read 300 degrees.
I then checked the power source, when I removed the fuse for it the neddle finally moved down to almost 0 degrees. Whats up with that?????:thud:
I looked at the power source and determine to hook straight to the ignition wire for the key, thinking maybe I was not always getting the right power. I also rechecked the ground wire as well and retightned it.
Does any one have any suggestions? I think this is why my gauge was reading funny!! what do you think!!:popcorn:
Discussion Starter · #2 ·
Does anyone have any suggestions!!!
It sounds to me like it's not wired properly. What brand gauge?
Diciprol gauge, it clearly states the red is for ignition switch power, grey and black is ground, white is lights then you have your 2 prong plug for the pyro. It has been on the truck for a while and have not had any issues until i put on the new turbo, maybe coinsedental. I do appreciate the feed back.
Pyro could have just died.
I have seen that before.
Check the pyro with a ohm meter to see what you get.:thumbsup
I will have my check it tomorrow with a meter to see wht I get, I started it a few minutes ago and seems to be working now. The whole thing is wierd!!
Smells like Bananas
i had a auto meter Pyro die after only four months. I thought it was the gauge but the fellow at Autometer told me that if i disconnect the pyro from the gauge. Power up the gauge, if the needle is between 0 to 100 degrees the gauge is fine and the pyro was bad. so it ended up being that the pyro was bad and they sent me a whole new pryo gauge set.
But the needle was all over the place when it went bad. Also the gauge would read fine until i pressed on the accelerator. the added heat on the probe would through it off but when i let off the needle would read fine.
SC Chapter President
This might not be helpful, but I have an autometer pyro and mine was doin the whole jumping around going crazy thing and I took it out, wiped it off and put it back in the manifold and have had no problems since.
Discussion Starter · #9 ·
95cummins12valve, I did the same thing, it seems to be working good for now. I think I will call the dealer I got mine from and see if he will send me a new probe just in case it happens again. You know this site is really awesomw for all of us guys who are do it yourselfers!!! I really appreciate everyones input to make this :peelout happen!! :lol3:
If you soldered the wires for the pyrometer, this may cause fluctuating temperature readings.
1 - 10 of 10 Posts
