1 - 11 of 11 Posts
I'm planing on putting on a 5" Rough Country this weekend and was wondering if i gust take out the leveling kit blocks that are already on the truck.
Oh the lift comes with coil springs for the front
if you have a leveling kit(spacer) in the front, just take it out when you put your new coils in.
If you have a poly/rubber spacer in the front, you more than likely don't still have the factory rubber coil retainer. If you have a steel front spacer, you might still have it. It is a rubber "circle" that is the same size of the top of your coil springs. It prevents you coils and coil buckets from having metal to metal contact, almost like a bushing.
It is a steel 2" spacer. If the factory rubber bushing is gone do i need one and if i do where do i get them at?
BUMP... I looked at the spacer and it has a rubber bushing in between the coil spring and the 2" spacer. Is that rubber piece part of the spacer or can i take it off and use it when i put the new coil spring in?
sorry, not trying to hijack and throw thread in a different direction, but Satan's Chariot what are you running for rubber on your rig? Shes got a mean bulldog stance in your avatar.
Yep, that's it. That goes between the coil and the coil bucket.
Northern CA Chapter President
and do you have the stock stud ring that holds your shock tower on?
or you could always leave the spacer on and have a 7'' lift :)
Thats what i did!! but you will need the rubber ring and the stud ring ike stated above. if you dont have them dodge place can get them or may have a set.
1 - 11 of 11 Posts
