1 - 20 of 44 Posts
I talked to a guy today about my fuel mileage and he suggested I run a quart of 2 stroke motor oil per full tank of diesel in my Cummins. He said he does in his and his buddies do in 7.3 powerstrokes. He claims it will help my truck get 2-3 more mpgs without harmful side effects. Anyone know about this??
Yes. I don't see crazy mpg gains because I don't think it helps that much. I like the extra lubrication.
So is it actually good for my motor over time? Injectors?
The lubrication will help. I notice a smoother running engine after adding 2 stroke. You will get a lot of people have 200k and never ran anything besides diesel and others who swear by running 2 stroke. Try it and decide for yourself. I usually run either powerservice or 2 stroke every tank.
The following are the preliminary results of a research study on diesel fuel Lubricity Additives. There is likely to be further commentary and explanation added at a future time.
PURPOSE:
The purpose of this research was to determine the ability of multiple diesel fuel additives to replace the vital lubricity component in ULSD (Ultra Low Sulfer Diesel) fuel.
HISTORY:
ULSD fuel is the fuel currently mandated for use in all on road diesel engines. This fuel burns cleaner and is less polluting than it’s predecessor, called Low Sulfer Diesel Fuel. Low sulfer fuel contained less than 500 ppm of sulfer. ULSD contains 15 ppm or less.
As diesel fuel is further refined to remove the polluting sulfer, it is inadvertently stripped of its lubricating properties. This vital lubrication is a necessary component of the diesel fuel as it prevents wear in the fuel delivery system. Specifically, it lubricates pumps, high pressure pumps and injectors. Traditional Low sulfer diesel fuel typically contained enough lubricating ability to suffice the needs of these vital components. ULSD fuel, on the other hand, is considered to be very “dry” and incapable of lubricating vital fuel delivery components. As a result, these components are at risk of premature and even catastrophic failure when ULSD fuel is introduced to the system. As a result, all oil companies producing ULSD fuel must replace the lost lubricity with additives. All ULSD fuel purchased at retail fuel stations SHOULD be adequately treated with additives to replace this lost lubricity. The potential result of using inadequately treated fuel, as indicated above, can be catastrophic. There have been many documented cases of randomly tested samples of diesel fuel. These tests prove that often times the fuel we purchase is not adequately treated and may therefore contribute to accelerated wear of our fuel delivery systems. For this reason it may be prudent to use an after market diesel fuel additive to ENSURE adequate lubrication of the fuel delivery system. Additionally, many additives can offer added benefits such as cetane improver, and water separators or emulsifiers.
CONTENT:
In this study we will test multiple diesel fuel additives designed to replace lost lubricity. The primary component of this study is a side-by-side laboratory analysis of each additive’s ability to replace this vital lubricity. Additionally, claims of improving cetane, water separation or emulsification, bio-diesel compatibility and alcohol content will be noted. These notes were derived from information that was readily available to consumers (via the label and internet information) and none of this information has been evaluated for validity and/or performance. Cetane information has only been noted if the word “cetane” was used in the advertising information. The words “improves power” has not been translated to mean “improves cetane” in this evaluation. Information on alcohol content is provided by indicating “contains no alcohol”. Omission of the words “contains no alcohol” does not imply that it does contain alcohol. This information was simply missing in the information available to a consumer. However, the possibility of a form of alcohol in these products is possible. Additionally, information on dosages and cost per tankful are included for comparison purposes.
How Diesel Fuel Is Evaluated For Lubricating Ability:
Diesel fuel and other fluids are tested for lubricating ability using a device called a “High Frequency Reciprocating Rig” or HFRR. The HFRR is currently the Internationally accepted, standardized method to evaluate fluids for lubricating ability. It uses a ball bearing that reciprocates or moves back and forth on a metal surface at a very high frequency for a duration of 90 minutes. The machine does this while the ball bearing and metal surface are immersed in the test fluid (in this case, treated diesel fuel). At the end of the test the ball bearing is examined under a microscope and the “wear scar” on the ball bearing is measured in microns. The larger the wear scar, the poorer the lubricating ability of the fluid. Southwest Research runs every sample twice and averages the size of the wear scar.
The U.S. standard for diesel fuel says a commercially available diesel fuel should produce a wear scar of no greater than 520 microns. The Engine Manufacturers Association had requested a standard of a wear scar no greater than 460 microns, typical of the pre-ULSD fuels. Most experts agree that a 520 micron standard is adequate, but also that the lower the wear scar the better.
METHOD:
An independent research firm in Texas was hired to do the laboratory work. The cost of the research was paid for voluntarily by the participating additive manufacturers. Declining to participate and pay for the research were the following companies: Amsoil and Power Service. Because these are popular products it was determined that they needed to be included in the study. These products were tested using funds collected by diesel enthusiasts at “dieselplace.com”. Additionally, unconventional additives such as 2-cycle oil and used motor oil were tested for their abilities to aid in diesel fuel lubricity. These were also paid for by members of “dieselplace.com”.
The study was conducted in the following manner:
-The Research firm obtained a quantity of “untreated” ULSD fuel from a supplier. This fuel was basic ULSD fuel intended for use in diesel engines. However, this sample was acquired PRIOR to any attempt to additize the fuel for the purpose of replacing lost lubricity. In other words, it was a “worst case scenario, very dry diesel fuel” that would likely cause damage to any fuel delivery system. This fuel was tested using the HFRR at the Southwest Research Laboratory. This fuel was determined to have a very high HFRR score of 636 microns, typical of an untreated ULSD fuel. It was determined that this batch of fuel would be utilized as the baseline fuel for testing all of the additives. The baseline fuel HFRR score of 636 would be used as the control sample. All additives tested would be evaluated on their ability to replace lost lubricity to the fuel by comparing their scores to the control sample. Any score under 636 shows improvement to the fuels ability to lubricate the fuel delivery system of a diesel engine.
BLIND STUDY:
In order to ensure a completely unbiased approach to the study, the following steps were taken:
Each additive tested was obtained independently via internet or over the counter purchases. The only exceptions were Opti-Lube XPD and the bio-diesel sample. The reason for this is because Opti-Lube XPD additive was considered “experimental” at the time of test enrollment and was not yet on the market. It was sent directly from Opti-Lube company. The bio-diesel sample was sponsored by Renewable Energy Group. One of their suppliers, E.H. Wolf and Sons in Slinger, Wisconsin supplied us with a sample of 100% soybean based bio-diesel. This sample was used to blend with the baseline fuel to create a 2% bio-diesel for testing.
Each additive was bottled separately in identical glass containers. The bottles were labeled only with a number. This number corresponded to the additive contained in the bottle. The order of numbering was done randomly by drawing names out of a hat. Only Spicer Research held the key to the additives in each bottle.
The additive samples were then sent in a box to An independent research firm. The only information given them was the ratio of fuel to be added to each additive sample. For example, bottle “A” needs to be mixed at a ratio of “480-1”. The ratio used for each additive was the “prescribed dosage” found on the bottle label for that product. Used motor oil and 2-cycle oil were tested at a rationally chosen ratio of 200:1.
The Research Laboratory mixed the proper ratio of each “bottled fluid” into a separate container containing the baseline fuel. The data, therefore, is meaningful because every additive is tested in the same way using the same fuel. A side-by-side comparison of the effectiveness of each additive is now obtainable.
THE RESULTS:
These results are listed in the order of performance in the HFRR test. The baseline fuel used in every test started at an HFRR score of 636. The score shown is the tested HFRR score of the baseline fuel/additive blend.
Also included is the wear scar improvement provided by the additive as well as other claimed benefits of the additive. Each additive is also categorized as a Multi-purpose additive, Multi-purpose + anti-gel, Lubricity only, non-conventional, or as an additive capable of treating both gasoline and diesel fuel.
As a convenience to the reader there is also information on price per treated tank of diesel fuel (using a 26 gallon tank), and dosage per 26 gallon tank provided as “ounces of additive per 26 gallon tank”.
In Order Of Performance:
1) 2% REG SoyPower biodiesel
HFRR 221, 415 micron improvement.
50:1 ratio of baseline fuel to 100% biodiesel
66.56 oz. of 100% biodiesel per 26 gallons of diesel fuel
Price: market value
2)Opti-Lube XPD
cetane improver, demulsifier
HFRR 317, 319 micron improvement.
256:1 ratio
13 oz/tank
$4.35/tank
3)FPPF RV, Bus, SUV Diesel/Gas fuel treatment
Gas and Diesel
cetane improver, emulsifier
HFRR 439, 197 micron improvement
640:1 ratio
5.2 oz/tank
$2.60/tank
4)Opti-Lube Summer Blend
Multi-purpose
demulsifier
HFRR 447, 189 micron improvement
3000:1 ratio
1.11 oz/tank
$0.68/tank
5)Opti-Lube Winter Blend
Muti-purpose + anti-gel
cetane improver
HFRR 461, 175 micron improvement
512:1 ratio
6.5 oz/tank
$3.65/tank
6)Schaeffer Diesel Treat 2000
cetane improver, emulsifier, bio-diesel compatible
HFRR 470, 166 micron improvement
1000:1 ratio
3.32 oz/tank
$1.87/tank
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
9)Amsoil Diesel Concentrate
Multi-purpose
demulsifier, bio-diesel compatible, alcohol free
HFRR 488, 148 micron improvement
640:1 ratio
5.2 oz/tank
$2.16/tank
10)Power Service Diesel Kleen + Cetane Boost
Multi-purpose
Cetane improver, bio-diesel compatible, alcohol free
HFRR 575, 61 micron improvement
400:1 ratio
8.32 oz/tank
$1.58/tank
11)Howe’s Meaner Power Kleaner
Multi-purpose
Alcohol free
HFRR 586, 50 micron improvement
1000:1 ratio
3.32 oz/tank
$1.36/tank
12)Stanadyne Performance Formula
cetane improver, demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 603, 33 micron improvement
480:1 ratio
6.9 oz/tank
$4.35/tank
13)Used Motor Oil, Shell Rotella T 15w40, 5,000 miles used.
Unconventional (Not ULSD compliant, may damage systems)
HFRR 634, 2 micron improvement
200:1 ratio
16.64 oz/tank
price: market value
14)Lucas Upper Cylinder Lubricant
Gas or diesel
HFRR 641, 5 microns worse than baseline (statistically insignificant change)
427:1 ratio
7.8 oz/tank
$2.65/tank
15)B1000 Diesel Fuel Conditioner by Milligan Biotech
Multi-purpose, canola oil based additive
HFRR 644, 8 microns worse than baseline (statistically insignificant change)
1000:1 ratio
3.32 oz/tank
$2.67/tank
16)FPPF Lubricity Plus Fuel Power
Emulsifier, alcohol free
HFRR 675, 39 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$1.12/tank
17)Marvel Mystery Oil
Gas, oil and Diesel fuel additive (NOT ULSD compliant, may damage 2007 and newer systems)
HFRR 678, 42 microns worse than baseline fuel.
320:1 ratio
10.4 oz/tank
$3.22/tank
18)ValvTect Diesel Guard Heavy Duty/Marine Diesel Fuel Additive
Multi-purpose
Cetane improver, emulsifier, alcohol free
HFRR 696, 60 microns worse than baseline fuel
1000:1 ratio
3.32 oz/tank
$2.38/tank
19)Primrose Power Blend 2003
Multi-purpose
Cetane boost, bio-diesel compatible, emulsifier
HFRR 711, 75 microns worse than baseline
1066:1 ratio
3.12 oz/tank
$1.39/tank
CONCLUSIONS:
Products 1 through 4 were able to improve the unadditized fuel to an HFRR score of 460 or better. This meets the most strict requirements requested by the Engine Manufacturers Association.
Products 1 through 9 were able to improve the unadditized fuel to an HFRR score of 520 or better, meeting the U.S. diesel fuel requirements for maximum wear scar in a commercially available diesel fuel.
Products 16 through 19 were found to cause the fuel/additive blend to perform worse than the baseline fuel. The cause for this is speculative. This is not unprecedented in HFRR testing and can be caused by alcohol or other components in the additives. Further investigation into the possibilities behind these poor results will investigated.
Any additive testing within +/- 20 microns of the baseline fuel could be considered to have no significant change. The repeatability of this test allows for a +/- 20 micron variability to be considered insignificant.
I run Super Tech Outboard 2-cycle TC-W3 engine oil, im sure it helps cylinder and injector lube, but I mainly run it to lubricate my CP3 pump, I did notice my CP3 and or motor was a bit smoother after a tank or two. one 16fl oz bottle per 31 gallons.
This has been posted 100+ times on CumminsForum,
Yep I always try to use Loves Truck Stop commerical B5.. Are commerical B99 poured into my tank to make B5 to B15.... Truck runs so much better and the CP3 and injectors/top cyn's are happy..
If not I put a quart of 30wt non-detergent in at least every few tanks.. other times some diesel clean..
INSERT ON ABOVE POST..
Actually cottonseed oil for bioblend would be the best!
With the warranty they give on these engines if Cummins or Chrysler thought you should use a lubricant it would be in the manual.....
We had 112 power rigs at Chrysler Transport, Windsor Terminal that ran average 20 hours a day, 6 days a week, got traded when they hit 1 million miles and NEVER put an additive in the fuel...
Wow that's impressive that not one of them EVER had a fuel injector, fuel pump problem, etc. That's 112,000,000 miles with no fuel problems.
Sent from my iPhone 4S app sucka!
I ran some 2-stroke oil in my truck on my last trip and got 17 mpg empty on the way home empty, and I normally get right close to 18 and have even gotten 19 once. I didn't think it was that windy but maybe it was.. either way I've never had good luck running 2-stroke oil. I've had decent luck with XDP's fuel additive, but then those might have been on lucky trips too, who knows.
I run 16 oz in my '07 every other tank, don't notice any mileage difference but it's a little quieter.
Ran 16 oz in my folks' '01 power stroke this past weekend. Just going by their over head (liar meter) which is normally very accurate I picked up about 4 miles per gallon empty and about the same pulling a 40 ft living qtr. horse trailer.
Same trip, about the same wind conditions were made a few weeks ago with the truck. Didn't hand calculate, but I do know we needed to fuel up before and I made it on one tank before this time.
Fuel came from the same place both times, only thing different was the addition of some Wally's two stroke????
Yes, and I guess the EPA and the current administration really know what they are talking about.:rof
Always ran atf in our 01 cummins,I tried 2 walmart 2 stroke in it and didnt get the smoothed out effect of the atf.On our 03 I figured id go with the atf as well,but I just didnt see the effect I got form it on the 01.So this last I tank I figured Id try wallys 2 stroke oil in the 03.It completely smoothed out the 03and the slight ticking it had.Not sure why but seems to me the cp3 like the 2 stroke oil and the vp44 like the atf.
Yes this was an EPA proposal but it had nothing to do with the current administration.
Bush was president when ULSD was mandated and Stephen L Johnson was head of EPA. Neither Bush or Johnson are part of the current administration.
when your manual was printed USLD didn't exist
well I had a long conversation with mopar1973man about this he also has a massive breakdown of this topic on his website. I myself tried the outboard 2 stroke right before my haul from san antone to houston and it seemed to help a lil but the biggest problem was I fought a major head wind the eeeeentire way there but my mileage seemed to improve a tad so probably did a good bit of help maybe 1 maybe 2 mpg. Now the problem with running used oil or atf ive seen pics of what that does to injector nozzles over time... holy crap you might wanna stop.
yall should definately check this out gooooobs of info this is just one article of 6 or more
Mopar1973Man's Dodge Cummins Articles - Adding 2 Cycle Oil To Diesel Fuel
Oh really? So my manual was printed 5 years before my truck was built? And you don't think Chrysler wouldn't put out a suppliment after the fact if ULSD was harming the older engines? You don't think Cummins would have it on its website?
I will always use Loves Truck stop B5.. It's BIG RIG 18 wheeler stuff.. Think thry would be using it if it was not any good.
Ditto that. The Love's down the road from me now has B10 stickers affixed to all of their pumps. I have zero issues driving an extra five miles for bio even though there is a dino diesel station about a mile from my place. I would run B20 as often as I could when I was stationed in Maryland and near Annapolis. I have 174,000 miles on my truck and at least 1/3 of those miles are running a biodiesel blend anywhere from B1-B99.
When I do run dino diesel I have switched from 2-stroke oil and now use Alterra DieselMaxx which I get locally for $12.50 agallon. If you go by the case study results that stuntjake posted (post #5), Alterra has a HFRR of 270 and one gallon treats 400 gallons of dino diesel. That puts it second only to biodiesel.
Without intentionally giving either argument more ammunition- forgive me if I'm overlooking an incredibly obvious piece of evidence ( because i do that all the fukkn time)
Is it not quite obvious that people stopped pulling 5,6, or 700,000 or even a million miles from a light duty pick up right around the same time the LSD and eventually ULSD was put on the market?
YES i know all the differences between a 94 12 valve 5.9 and an 04 HPCR 5.9, but I highly doubt the engineers would let any of those differences directly hinder the longevity of the engine.
And on that note, who cares what the factory says! the ball bearing is TRUTH. SEEK THE TRUTH. haha
1 - 20 of 44 Posts
