I bought a Holley Blue pump to replace my broken lift pump. Where would be the best place to install it? And so some pix if you have them.
-thanks
and everything else stays the same? Do I tap the power from the rear or run it from the front?
I just put in a Holley Blue pump about 2 weeks ago. I would highly reccomend going with a big line kit form Vulcan performance. It replaces all the factory lines from the tank to the injection pump with 1/2" line and includes all the fittings required(you would also nee dthe draw straw II to go with it. Its a fairly easy job, a lift sure makes it easier.
