Remove the radiator core support to slow for more room. Remove engine mounts top and bottom. Unbolt tranny with a jack under it for support. These engines weigh around 1000k so be sure you have a cherry picker able to handle that weight. Make a stand from 2x4 wood. Bolt it to the block. Doesn't have to look pretty just needs to be able to hold the engine safely. Then, once loaded in transport pickup tie it in with a few ratchet straps.
