This is for 5" lift with a dt-track bar using your anti-swaybar.
First off-
The cylinder assist kits are- make it work kits.
Second-I had a hard time finding a good place for the cylinder to be placed where I liked it (out of the way of obstacles and good for geometry and articulation).
The best place I found to mount the cylinder is to the diff. cover, aftermarket of course.
To do this you will also need to make your own or have a custom cross-over steering made to clear everything.
Third- my dt probab track bar hit the hydraulic cylinder so it had to be bent. Since I had the original aluminum bar I had to get the new steel bar.
I will post all the parts I needed and the suppliers later if you guys are interested.
First off-
