1 - 3 of 3 Posts
I am new to the diesel world and just want to ask a question about the smoke that comes out of the truck. Every one says black smoke is good white is bad.
So I just wanted to ask because I may be just paranoid about this?
I just bought a 95 dodge with 75k miles on it and have be driving it for a while when it was warm, black smoke would come out when I hit the gas hard.
Now winter has set in and when the truck is warm charcoal smoke comes out when I hit it. Is this normal or should it be dark black?
when I start it in the morning and it is cold a little whit smoke comes out ( like most cars do at this time of the year) Then when it warms up there is no smoke at all and if I blip the throttle a puff of black smoke comes out. Normal driving no smoke comes out.
Thanks for your help
The Uppity 12v Admin
White smoke is just unburned fuel vapor. You're likely going to get it on a cold engine. Mine doesn't give any white smoke when it's warmer even on cold starts. Lately I get a white puff on startup.
In cold weather diesel fuel does not completely atomize and burn instantly and completely. This lack of burning well creates white smoke. When the truck has warmed up (or is warm enough) black smoke can happen when it first starts or when it gets to much fuel for the air available. My truck would blow a puff of black smoke in summer when I hit the throttle starting. In cold weather (like now) white smoke happens. Both are normal.
If you see white smoke when the truck is warmed up that is not normal.
1 - 3 of 3 Posts
